[GRASS-dev] RE: [GRASS-user] Question with Python-SWIG example [SEC=UNCLASSIFIED]
Martin Landa landa.martin at gmail.com
Thu May 20 09:46:00 EDT 2010
2010/5/19 Glynn Clements <glynn at gclements.plus.com>:
>> > This particular issue should be fixed by r42311. I don't know if this
>> > is related to the problem, but it's something to eliminate.
>> right, this issue is eliminated, anyway the reported problem still persists.
> The only other thing which I can suggest is to add print statements to
> the functions in $GISBASE/etc/python/grass/lib/ctypesheader.py,
> specifically String.__init__ and String.from_param.
hm, seems to be OK
String.from_param(): $Revision: 41297 $
String.__init__(): $Revision: 41297 $
String.from_param(): /home/martin/smetiste/example7.py
String.__init__(): /home/martin/smetiste/example7.py
String.from_param(): elevation
String.__init__(): elevation
String.__init__():
WARNING: Illegal filename <L�����>. Character <�> not allowed.
String.__init__(): String.from_param(): �
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
