[GRASS-dev] Re: [GRASS-user] grass 7 monitor
Tue May 25 04:52:01 EDT 2010
Hamish wrote:
> > > - python scripts are not happy on WinGrass (apparently
> > > ok in 6.5, so selective backporting of code should fix
> > > this)
> Markus N:
> > Where to look into that?
> the trick is knowing what needs backporting :)
> AFAIU Glynn's last comments on it stated that g.parser's -s flag had been
> backported already but the grass.python library needed to be updated to
> use it.
That was the situation for RC6; the Python side has since been updated
in the 6.4 branch.
