[GRASS-dev] Re: [GRASS GIS] #699: v.buffer segfault: in
Vect_get_isle_points()
trac at osgeo.org
Thu Nov 4 14:45:04 EDT 2010
#699: v.buffer segfault: in Vect_get_isle_points()
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Vector | Version: 6.4.0 RCs
Keywords: v.buffer | Platform: All
Cpu: All |
Comment(by mlennert):
Replying to [comment:5 mmetz]:
> The segfault is fixed in 6.4 r38554, but the other problems remain.
I still get a segfault in all three version (6.4, 6.5 and trunk). In 6.4:
v.generalize railroads out=rail_simple method=douglas_reduction
reduction=20
v.buffer rail_simple dist=1000 out=rail1000
results in:
Starting program: /home/mlennert/SRC/GRASS/grass-6.4.0/dist.i686-pc-linux-
gnu/bin/v.buffer in=rail_simple dist=1000 out=rail1000
[Thread debugging using libthread_db enabled]
warning: Lowest section in /usr/lib/libicudata.so.38 is .hash at 000000b4
[New Thread 0xb55c16d0 (LWP 31004)]
Buffering lines...
5%
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0xb55c16d0 (LWP 31004)]
0xb7ed0d00 in pg_create (Points=0x86b6558) at dgraph.c:471
471 v = si->ip[si->il[i].a[0].ip].group;
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/699#comment:7>
