[GRASS-dev] Help - run r.profile through python
melolp
melolp at gmail.com
Thu Nov 4 20:35:20 EDT 2010
Hi all,
I need some help since I'm new using GRASS functions through python.
I'm trying to use the function r.profile.
My code:
from grass.script import raster as grass
os.chdir('F:\GEOSTORM\Python scripts')
grass.run_command("r.profile",-g,input= teste1,output = teste, [12244.256
-295112.597,12128.012 -295293.77])
However I'm having the following error mesage:
"non-keyword arg after keyword arg grass.run_command"
Does someone can help me to write the correct code to call the r.profile
function from GRASS.
Best regards,
Pedro
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Help-run-r-profile-through-python-tp5707457p5707457.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
