[GRASS-dev] ERROR: G_realloc: during r.to.vect call
Markus Neteler
neteler at osgeo.org
Thu Nov 18 15:04:48 EST 2010
2010/11/18 António Rocha <antonio.rocha at deimos.com.pt>:
> Greetings
> I'm running GRASS (in Windows) and, for a specific raster, when I try to run
> v.to.rast I get this error:
> ERROR: G_realloc: unable to allocate 33760000 bytes at areas.c:678
> 1- Is this expectable?
> 2- is there any fix for this? If not, does anyone has any suggestion to
> avoid this error?
Did you check the computation region with
g.region -p
? Just to be sure that extent and resolution are right...
Markus
