[GRASS-dev] Re: [GRASS GIS] #224: cache bug in DGLib
Radim Blazek
radim.blazek at gmail.com
Sat Nov 20 07:48:03 EST 2010
Hi all,
what is the current situation with cache bug in dglib?
I found that in 6.4.0 it is still buggy but it is enabled in Vlib/net.c,
so all the net modules may give wrong results.
Definitely if the cache is buggy it should not be enabled.
Radim
> Reporter: martinl | Owner: grass-dev@…
> Type: defect | Status: closed
> Priority: major | Milestone: 6.4.1
> Component: Vector | Version: 6.4.0
> Resolution: fixed | Keywords: dglib, cache, v.net.path
> Platform: All | Cpu: All
> Changes (by mmetz):
> * status: reopened => closed
> * resolution: => fixed
> Comment:
> Replying to [comment:19 huhabla]:
> > I have tested v.net.path with a large dataset (460000 lines and 100
> check points) with and without cache support.
> > The results are identical.
> Great, thanks for testing!
> > I think we can close this ticked when the changes are backported to
> 6.4.1.
> Done in r44066 and r44067. Closing ticket.
> Markus M
> Ticket URL: <https://trac.osgeo.org/grass/ticket/224#comment:20>
> GRASS GIS <http://grass.osgeo.org>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
