[GRASS-dev] Re: [GRASS GIS] #224: cache bug in DGLib
Markus Neteler
neteler at osgeo.org
Sat Nov 20 08:29:16 EST 2010
Hi Radim,
On Sat, Nov 20, 2010 at 1:48 PM, Radim Blazek <radim.blazek at gmail.com> wrote:
> Hi all,
> what is the current situation with cache bug in dglib?
> I found that in 6.4.0 it is still buggy but it is enabled in Vlib/net.c,
> so all the net modules may give wrong results.
> Definitely if the cache is buggy it should not be enabled.
Did you try with 6.4.0 or the (later fixed) 6.4.svn? If it still fails
with the current 6.4.svn, do you have a test case?
>> Ticket URL: <https://trac.osgeo.org/grass/ticket/224#comment:20>
Markus
