[GRASS-dev] Re: [GRASS GIS] #224: cache bug in DGLib
Radim Blazek
radim.blazek at gmail.com
Sun Nov 21 10:33:42 EST 2010
The problem was with 6.4.0, current 6.4 svn seems to work OK.
Thanks
Radim
On Sat, Nov 20, 2010 at 2:29 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi Radim,
> On Sat, Nov 20, 2010 at 1:48 PM, Radim Blazek <radim.blazek at gmail.com> wrote:
>> Hi all,
>> what is the current situation with cache bug in dglib?
>> I found that in 6.4.0 it is still buggy but it is enabled in Vlib/net.c,
>> so all the net modules may give wrong results.
>> Definitely if the cache is buggy it should not be enabled.
> Did you try with 6.4.0 or the (later fixed) 6.4.svn? If it still fails
> with the current 6.4.svn, do you have a test case?
>>> Ticket URL: <https://trac.osgeo.org/grass/ticket/224#comment:20>
> Markus
