[GRASS-dev] [GRASS GIS] #1220: Error when creating vector(areas)
from raster
trac at osgeo.org
Mon Nov 22 04:40:42 EST 2010
#1220: Error when creating vector(areas) from raster
Reporter: toyzerocha1980 | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.1
Component: Vector | Version:
Keywords: | Platform: MSWindows XP
Cpu: x86-32 |
I'm trying to create a vector (areas) from a big LandUSe/LandCover map
with a lot of small patterns so, I believe that I have a lot of polygons
I'm using this expression:
r.to.vect -v input=map output=test02 feature=area
And I get this error:
Extracting areas...
Building topology for vector map <test02>...
Registering primitives...
820000ERROR: G_realloc: unable to allocate 9900000 bytes at cindex.c:108
A few days ago, with other image I have obtained almost tghe same error
but a bit different:
ERROR: G_realloc: unable to allocate 33760000 bytes at areas.c:678
My Region is defined as:
projection: 99 (Transverse Mercator)
zone: 0
datum: etrs89
ellipsoid: grs80
north: -4772.159565
south: -300404.804
west: -28364.80083451
east: 105242.8746
nsres: 30.00128318
ewres: 29.99723292
rows: 9854
cols: 4454
cells: 43889716
I'm going to try in Linux and I wil reply on this right next.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1220>
