[GRASS-dev] Re: [GRASS GIS] #1220: Error when creating
vector(areas) from raster
trac at osgeo.org
Mon Nov 22 07:30:29 EST 2010
#1220: Error when creating vector(areas) from raster
Reporter: toyzerocha1980 | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.1
Component: Vector | Version:
Keywords: | Platform: MSWindows XP
Cpu: x86-32 |
Comment(by toyzerocha1980):
Hi
Still in Windows: It has created a vector file and it seems ok (in extent)
But If I use v.what I get:
v.what --q -a map=test03 at National east_north=66367.029426,-51132.981541
distance=220.079183
Coor files of vector map <test03 at National> is larger than it should be
(99266507 bytes excess)
ERROR: You must build topology on vector map <teste03 at National>
(Mon Nov 22 12:21:03 2010) Command finished (0 sec)
And I'm not able to add any column v.db.addcol and Vector does not have
any topology...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1220#comment:1>
