[GRASS-dev] Re: [GRASS GIS] #1220: Error when creating vector(areas) from raster
GRASS GIS trac at osgeo.org
Mon Nov 22 16:31:25 EST 2010
 Reporter:  toyzerocha1980  |       Owner:  grass-dev@…
     Type:  defect          |      Status:  new
 Priority:  blocker         |   Milestone:  6.4.1
Component:  Vector          |     Version:
 Keywords:                  |    Platform:  MSWindows XP
      Cpu:  x86-32          |
Comment(by neteler):
 Replying to [comment:2 toyzerocha1980]:
 > Ok I have decided to create/build topology
 > v.build map=test10 at National error=error10
 > Coor files of vector map <teste10 at National> is larger than it should be
 (99266507 bytes excess)
 > Building topology for vector map <teste10>...
 > Registering primitives...
 > 1874449 primitives registered
 > 5317522 vertices registered
 > Building areas...
 > 601738 areas built
 > 117075 isles built
 perhaps you exceed the 2Gb limit here? GRASS 7 supports large file support
 (LFS).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1220#comment:3>
