[GRASS-dev] Re: [GRASS GIS] #1223: g.mapsets access from menu broken
trac at osgeo.org
Thu Nov 25 12:50:39 EST 2010
Reporter: cmbarton | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: | Platform: MacOSX
Cpu: OSX/Intel |
Comment(by glynn):
Replying to [comment:4 glynn]:
> The real problem is that "required" options have to be marked as
optional if there are any special cases which eliminate the requirement,
e.g. the "-l" flag in the case of g.mapsets.
My mistake; g.mapsets really doesn't have any required options. If it does
nothing when no options are given, it should probably at least generate an
error along the lines of "at least one of ... must be given".
Ticket URL: <http://trac.osgeo.org/grass/ticket/1223#comment:5>
