[GRASS-dev] Re: [GRASS GIS] #1223: g.mapsets access from menu broken
GRASS GIS trac at osgeo.org
Thu Nov 25 13:28:33 EST 2010
 Reporter:  cmbarton   |       Owner:  martinl
     Type:  defect     |      Status:  assigned
 Priority:  normal     |   Milestone:  7.0.0
Component:  wxGUI      |     Version:  svn-trunk
 Keywords:             |    Platform:  MacOSX
      Cpu:  OSX/Intel  |
Comment(by martinl):
 Replying to [comment:5 glynn]:
 > > The real problem is that "required" options have to be marked as
 optional if there are any special cases which eliminate the requirement,
 e.g. the "-l" flag in the case of g.mapsets.
 > My mistake; g.mapsets really doesn't have any required options. If it
 does nothing when no options are given, it should probably at least
 generate an error along the lines of "at least one of ... must be given".
 in the case that {{{GRASS_GUI}}} is not 'text' better to launch GUI
 dialog.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1223#comment:6>
