[GRASS-dev] [GRASS GIS] #1185: v.in.ogr on WinGrass: "Bad file descriptor"
GRASS GIS trac at osgeo.org
Fri Oct 1 07:40:09 EDT 2010
 Reporter:  hamish              |       Owner:  grass-dev@…
     Type:  defect              |      Status:  new
 Priority:  normal              |   Milestone:  6.4.1
Component:  Vector              |     Version:  unspecified
 Keywords:  v.in.ogr, wingrass  |    Platform:  MSWindows XP
      Cpu:  Unspecified         |
 Hi, this was posted to the wiki by "JeeJah".
 Not tested, no other idea about it. version and binary build unknown. But
 it warrants looking into..
 When importing an ESRI shapefile using the v.in.ogr
 command the following error may occur:
 [Bad file descriptor: Files]
 The output vector file is created but GRASS is "unable
 to open the vector map."
 Sample dialog:
 [v.in.ogr dsn=D:\acadia\Skyland\ortho\G_Ortho_Index.shp \
   output=orthoindex01
 Projection of input dataset and current location appear to match
 Layer: G_Ortho_Index
 Please note that the data are left in incosistent stage
 and can be corrupted (Thu Sep 30 14:15:16 2010) Command
  aborted (20 sec)]
 Solution:
 HB: It seems you found a bug: "C:\Program" got sent as the first argument,
 and the second half, "Files\GRASS-64\..." was sent as the second argument.
 Somewhere some path variable is not quoted correctly to protect against
 spaces in pathnames.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1185>
