[GRASS-dev] Re: [GRASS GIS] #1185: v.in.ogr on WinGrass: "Bad file
descriptor"
trac at osgeo.org
Fri Oct 1 14:13:27 EDT 2010
#1185: v.in.ogr on WinGrass: "Bad file descriptor"
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Vector | Version: unspecified
Keywords: v.in.ogr, wingrass | Platform: MSWindows XP
Cpu: Unspecified |
Comment(by hellik):
Replying to [ticket:1185 hamish]:
> Hi, this was posted to the wiki by "JeeJah".
> Not tested, no other idea about it. version and binary build unknown.
But it warrants looking into..
> When importing an ESRI shapefile using the v.in.ogr
> command the following error may occur:
> [Bad file descriptor: Files]
> The output vector file is created but GRASS is "unable
> to open the vector map."
> Sample dialog:
> [v.in.ogr dsn=D:\acadia\Skyland\ortho\G_Ortho_Index.shp \
> output=orthoindex01
> Projection of input dataset and current location appear to match
> Layer: G_Ortho_Index
> Please note that the data are left in incosistent stage
> and can be corrupted (Thu Sep 30 14:15:16 2010) Command
> aborted (20 sec)]
> Solution:
> HB: It seems you found a bug: "C:\Program" got sent as the first
argument, and the second half, "Files\GRASS-64\..." was sent as the second
argument. Somewhere some path variable is not quoted correctly to protect
against spaces in pathnames.
test with the actual WinGrass64-release (installed in c:\Program
Files\...):
v.in.ogr --verbose dsn=C:\wd\gextension\firestations.shp
output=testvimport
Die Projektionsinformationen des Eingabedatensatzes und der aktuellen
Location scheinen übereinzustimmen.
Layer: firestations
Spaltenname wurde geändert: 'cat' -> 'cat_'
Importiere 71 Objekte der Karte...
Erstelle Topologie für die Vektorkarte <testvimport>...
Registriere Primitive...
71 Primitive registriert
71 Vertices registriert
Erzeuge Flächen...
0 Flächen angelegt
0 Inseln angelegt
Füge Inseln hinzu...
Füge Zentroide hinzu...
Die Topologie wurde erstellt
Anzahl der Knoten: 71
Anzahl der Primitive: 71
Anzahl der Punkte: 71
Anzahl der Linien: 0
Anzahl der Grenzen: 0
Anzahl der Zentroide: 0
Anzahl der Flächen: 0
Anzahl der Inseln: 0
(Fri Oct 01 20:08:31 2010) Command finished (0 sec)
it works. I would vote for closing the ticket.
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1185#comment:1>
