[GRASS-dev] Re: [GRASS GIS] #1178: WinGrass: g.extension - problem
with path to $GISBASE
trac at osgeo.org
Fri Oct 1 18:27:40 EDT 2010
#1178: WinGrass: g.extension - problem with path to $GISBASE
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: Installation | Version: svn-releasebranch64
Keywords: wingrass, g.extension, path, installation, addons | Platform: MSWindows Vista
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:16 hamish]:
> Replying to [comment:14 hellik]:
> > p.s. noted that this is a statical approach, but at the moment
> > it's a chance to test g.extension in wingrass. later on - after
> > testing g.extension - it could be changed into a dynamically
> > approach as described in comment:7
> right, notice in the above comment:7 you get:
> %~s1 = C:\PROGRA~1\GRASS-~2\
> as you have more than 1 grass installed. Of course people will add and
remove different grasses after the initial install, so setting it to the
shortened version as it was at install time is not ideal.
but we are already there, see
(see
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/mswindows
/GRASS-Installer.nsi#L812)
;create the $INSTALL_DIR\msys\etc\fstab with the main grass dir mount info
ClearErrors
FileOpen $0 $INSTALL_DIR\msys\etc\fstab w
IfErrors done_create_fstab
FileWrite $0 '$INST_DIR_SHORT /grass$\r$\n'
FileClose $0
done_create_fstab:
which leads on my laptop after a lot install/deinstall from different
WinGrass64/65/70-versions to
C:\PROGRA~1\GRASS-~3 /grass
which is different of situation at installation time.
I have no idea at the moment if this (;create the
$INSTALL_DIR\msys\etc\fstab with the main grass dir mount info)affects a
WinGrass-installation?
> ps- why not "C:\Program Files\GRASS-6.4.SVN" ? -64- looks a little weird
to me and could be confused with 64bit. does the .4 or .svn get mistaken
for a file type? On the other hand, final \GRASS-64 (or is it GRASS-640?)
fits into 8.3 already which avoids some of the shortname headaches. Same
for the names in the Start menu structure.
I would vote for a rearrangement/renaming of the WinGrass-installation if
this could enhance the situation.
any hints for suitable naming convention for the different WinGrass-
Versions?
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1178#comment:17>
