[GRASS-dev] Re: [GRASS GIS] #584: vector directed graph library BUG2
trac at osgeo.org
Tue Oct 12 05:31:46 EDT 2010
Reporter: mmetz | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-develbranch6
Keywords: shortest path, edge costs | Platform: Unspecified
Cpu: Unspecified |
Comment(by mmetz):
I did some testing and found out that
* I could only reproduce BUG2 with cache enabled
* BUG2 occurred only if the path to the node closer to start was
requested first
* BUG2 occurred only if the distance or cumulative cost was requested and
not the actual path
BUG2 is now fixed in trunk and devbr6, at least I can no longer reproduce
it, but maybe I have overlooked some special case.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/584#comment:3>
