[GRASS-dev] backport r.proj -p, -g to 6.4.1svn?
Wed Oct 13 07:46:10 EDT 2010
Hamish wrote:
> any objections to backporting r.proj -p and -g flags? it makes it so you
> don't need the v.in.region + v.proj tricks and makes the work flow a lot
> easier (no need to change GRASS sessions).
IMHO, the documentation should be updated to indicate that the
information is only an estimate.
Better still would be to use the improved estimate obtained from
bordwalk(), which will be reasonably accurate except in pathological
cases. The four-corners estimate could be significantly off for cases
such as projecting lat-lon to LCC.
