[GRASS-dev] bilinear and bicubic raster interpolation
Glynn Clements
glynn at gclements.plus.com
Mon Oct 18 06:04:38 EDT 2010
Markus Neteler wrote:
> > Also, I believe that the off-by-half issue (r43943) affects the 6.x
> > r.proj, which will need a similar fix (but which will need to be done
> > manually). r43944 is only applicable to the newer version (r.proj.seg
> > and 7.0), not the 6.x r.proj.
> AFAIK we have r.proj.seg everywhere.
Right; in 6.x, raster/r.proj isn't built, and raster/r.proj.seg is
built as r.proj. In which case, raster/r.proj should probably be
removed if it isn't going to be fixed.
