[GRASS-dev] bilinear and bicubic raster interpolation
Markus Metz
markus.metz.giswork at googlemail.com
Mon Oct 18 11:32:28 EDT 2010
>> However, there is another issue with r.proj (7.0) and r.proj.seg
>> (6.x): bilinear and cubic interpolation give a small number of garbage
>> results due to incorrect use of the caching mechanism (blocks are
>> being replaced while references remain). I'll fix this shortly.
> This should be fixed by r43944.
and for i.rectify (7.0) in 43973
Markus M
