[GRASS-dev] Re: [GRASS GIS] #1159: v.in.ascii fails with long text file in WinGRASS-6.4.0-1
GRASS GIS trac at osgeo.org
Thu Sep 16 19:48:47 EDT 2010
 Reporter:  lponti      |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  6.4.1
Component:  Vector      |     Version:  6.4.0
 Keywords:  v.in.ascii  |    Platform:  MSWindows 7
      Cpu:  x86-32      |
Comment(by hamish):
 ok, thanks,
 D2/3: Write 71 rows
 D2/3: Written 71 records
 Fülle Tabelle...
 D2/3: db_close_database() result: 0  (0 means success)
 D2/3: db_shutdown_driver() failed
 ok, from Luigi's tests we know it is DB backend independent, and from
 Helmut's test we know it is the driver shutdown not the closing of the
 database.
 ERROR: Konnte Attributetabelle nicht schliessen. Der DBMI-Treiber hat
 nicht alle Attribute akzeptiert.
 (could you run with "LANG=C v.in.ascii ..."? I can guess the meaning but
 my deutsch is not as good as your english..)
 in 6.5svn db_shutdown_driver() for WinGrass effectively boils down to:
 #include <stdlib.h>
 #include <process.h>
 #include <grass/dbmi.h>
 #include "macros.h"
   \brief Closedown the driver, and free the driver structure
   <b>Note:</b> the management of the memory for the driver structure
   probably should be handled differently.
   db_start_driver() could take a pointer to driver structure as
   an argument, instead of returning the pointer to allocated
   then there would be no hidden free required
   \param driver db driver
   \return status (?)
 int db_shutdown_driver(dbDriver * driver)
     int status;
     db__set_protocol_fds(driver->send, driver->recv);
     DB_START_PROCEDURE_CALL(DB_PROC_SHUTDOWN_DRIVER);
     /* close the communication FILEs */
     fclose(driver->send);
     fclose(driver->recv);
     driver->send = NULL;
     driver->recv = NULL;
     /* wait for the driver to finish */
     status = -1;
     /* TODO: convert status to something like from wait? */
     _cwait(&status, driver->pid, WAIT_CHILD);
     driver->pid = 0;
     /* free the driver structure. THIS IS GOOFY */
     free(driver);
     return status;
 but that's about all the help I can give,
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159#comment:7>
