[GRASS-dev] Re: [GRASS GIS] #1158: g.mremove fails when used with
wildcard in WinGRASS-6.4.0-1
trac at osgeo.org
Fri Sep 17 14:03:54 EDT 2010
#1158: g.mremove fails when used with wildcard in WinGRASS-6.4.0-1
Reporter: lponti | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Vector | Version: 6.4.0
Keywords: g.mremove, wildcards | Platform: MSWindows 7
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:2 hellik]:
> Replying to [comment:1 hellik]:
> > Replying to [ticket:1158 lponti]:
> > > wxgui g.mremove called on vector with * wildcard does not work:
> > I can confirm this (WinVista23-box).
> > but it's very interesting:
> > a first run of
> > g.mremove -f vect=map*
> > gets following
> > Unable to delete file
'C:\cygwin\home\andy/latlong/luigi/vector/mapBloomday_Olive_11set10_Avg/hist'
> > there seems to be a problem with the hist-section of the Grass-vector-
data-structure.
> > but in a second run of
> > all vector maps marked by the *-wildcard are deleted.
> > Helmut
> tested also with the latest wingrass65-nightly build. there also you
need two runs of g.mremove -f to remove a vector map.
> Helmut
also tested in a self built WinGrass7, this issue can be confirmed also be
there.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1158#comment:4>
