[GRASS-dev] Re: [GRASS GIS] #1158: g.mremove fails when used with
wildcard in WinGRASS-6.4.0-1
trac at osgeo.org
Sat Sep 25 19:17:41 EDT 2010
#1158: g.mremove fails when used with wildcard in WinGRASS-6.4.0-1
Reporter: lponti | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Vector | Version: 6.4.0
Keywords: g.mremove, wildcards | Platform: MSWindows 7
Cpu: x86-32 |
Comment(by lponti):
I was wondering whether this is actually a normal priority ticket. I gave
it normal just because it is the default, but sounds like a fairly
important command is affected. WinGRASS has been doing so much better
recently, and I believe wild card-based removal of vector is an important
component of GRASS shell scripts.
I routinely use a series of shell scripts that include the following GRASS
commnands: g.parser, g.mapset, g.region, g.copy, g.mremove, v.in.ascii,
v.extract, v.to.rast, v.proj, v.db.addcol, v.what.rast, v.voronoi,
v.category, v.surf.idw, r.mapcalc, r.colors, r.report, r.univar, d.erase,
d.rast, d.vect, d.his, d.grid, d.legend, d.text, d.mon, d.histogram.
Kind regards,
Luigi
Ticket URL: <http://trac.osgeo.org/grass/ticket/1158#comment:5>
