[GRASS-dev] Re: [GRASS GIS] #1159: v.in.ascii fails with long text
file in WinGRASS-6.4.0-1
trac at osgeo.org
Fri Sep 17 14:30:50 EDT 2010
#1159: v.in.ascii fails with long text file in WinGRASS-6.4.0-1
Reporter: lponti | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Vector | Version: 6.4.0
Keywords: v.in.ascii | Platform: MSWindows 7
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:10 hellik]:
> Replying to [comment:9 glynn]:
> > Replying to [comment:7 hamish]:
> > > in 6.5svn db_shutdown_driver() for WinGrass effectively boils down
to:
> > _cwait(&status, driver->pid, WAIT_CHILD);
> > The MSVCRT documentation for _cwait() says:
> > The value of procHandle passed to _cwait should be the value returned
by
> > the call to the _spawn function that created the specified process.
> > Except, db_start_driver() no longer uses spawn(), it uses
G_spawn_ex(), which uses CreateProcess(). See r42651 (7.0) and r42654
(6.5).
> My test mentioned above was in WinGrass65.
> Helmut
I've tested this now in a self built WinGrass7 (nc-sampledata)
v.out.ascii --verbose input=myfireg7 at g7 layer=1
output=C:\wd\grassascii\firestation_ascii_point_g7.txt columns=CITY
format=point
and the a re-import with v.in.ascii
v.in.ascii -n --verbose
input=C:\wd\grassascii\firestation_ascii_point_g7.txt
output=vinasciig7withtable2
BUG in Beschreibungen, Option 'Punkt' in <format> existiert nicht.
BUG in Beschreibungen, Option 'Standard' in <format> existiert nicht.
D2/3: Vect_open_new(): name = vinasciig7withtable2
D1/3: Vect_set_thresh(): thresh = 0.000000
D1/3: G_find_vector2(): name=vinasciig7withtable2 mapset=g7
D1/3: V1_open_new_nat(): name = vinasciig7withtable2
D1/3: Vect_get_thresh(): thresh = 0.000000
D1/3: dig__write_head()
D1/3: write coor size (9850026457038848) to head
D2/3: coor body offset 17179869202
D3/3: dig_init_plus()
D3/3: dig_cidx_init()
D1/3: Vect_open_sidx(): name = vinasciig7withtable2 mapset=
g7 mode = new
D2/3: G__read_Cell_head
D2/3: G__read_Cell_head_array
D3/3: region item: proj: 99
D3/3: region item: zone: 0
D3/3: region item: north: 228500
D3/3: region item: south: 215000
D3/3: region item: east: 645000
D3/3: region item: west: 630000
D3/3: region item: cols: 1500
D3/3: region item: rows: 1350
D3/3: region item: e-w resol: 10
D3/3: region item: n-s resol: 10
D3/3: region item: top: 1
D3/3: region item: bottom: 0
D3/3: region item: cols3: 1500
D3/3: region item: rows3: 1350
D3/3: region item: depths: 1
D3/3: region item: e-w resol3: 10
D3/3: region item: n-s resol3: 10
D3/3: region item: t-b resol: 1
D3/3: Vect_hist_command()
D3/3: G_recreate_command()
Scanne die Eingabe zur Ermittelung der Spaltentypen...
D3/3: row 1 : 45 chars
D3/3: row 2 : 45 chars
D3/3: row 3 : 38 chars
D3/3: row 4 : 38 chars
D3/3: row 5 : 46 chars
D3/3: row 6 : 47 chars
D3/3: row 7 : 40 chars
D3/3: row 8 : 41 chars
D3/3: row 9 : 38 chars
D3/3: row 10 : 39 chars
D3/3: row 11 : 38 chars
D3/3: row 12 : 39 chars
D3/3: row 13 : 39 chars
D3/3: row 14 : 39 chars
D3/3: row 15 : 42 chars
D3/3: row 16 : 42 chars
D3/3: row 17 : 42 chars
D3/3: row 18 : 42 chars
D3/3: row 19 : 42 chars
D3/3: row 20 : 42 chars
D3/3: row 21 : 42 chars
D3/3: row 22 : 42 chars
D3/3: row 23 : 41 chars
D3/3: row 24 : 42 chars
D3/3: row 25 : 42 chars
D3/3: row 26 : 42 chars
D3/3: row 27 : 42 chars
D3/3: row 28 : 41 chars
D3/3: row 29 : 41 chars
D3/3: row 30 : 45 chars
D3/3: row 31 : 45 chars
D3/3: row 32 : 42 chars
D3/3: row 33 : 41 chars
D3/3: row 34 : 42 chars
D3/3: row 35 : 42 chars
D3/3: row 36 : 42 chars
D3/3: row 37 : 45 chars
D3/3: row 38 : 46 chars
D3/3: row 39 : 46 chars
D3/3: row 40 : 42 chars
D3/3: row 41 : 46 chars
D3/3: row 42 : 46 chars
D3/3: row 43 : 42 chars
D3/3: row 44 : 42 chars
D3/3: row 45 : 42 chars
D3/3: row 46 : 42 chars
D3/3: row 47 : 42 chars
D3/3: row 48 : 42 chars
D3/3: row 49 : 41 chars
D3/3: row 50 : 42 chars
D3/3: row 51 : 42 chars
D3/3: row 52 : 39 chars
D3/3: row 53 : 37 chars
D3/3: row 54 : 42 chars
D3/3: row 55 : 42 chars
D3/3: row 56 : 42 chars
D3/3: row 57 : 41 chars
D3/3: row 58 : 42 chars
D3/3: row 59 : 41 chars
D3/3: row 60 : 46 chars
D3/3: row 61 : 38 chars
D3/3: row 62 : 46 chars
D3/3: row 63 : 41 chars
D3/3: row 64 : 41 chars
D3/3: row 65 : 48 chars
D3/3: row 66 : 45 chars
D3/3: row 67 : 42 chars
D3/3: row 68 : 42 chars
D3/3: row 69 : 39 chars
D3/3: row 70 : 47 chars
D3/3: row 71 : 48 chars
Maximale Länge der Inputzeile: 49
Maximale Anzahl der Spalten: 4
Minimale Anzahl der Spalten: 4
D1/3: Vect_default_field_info(): map = vinasciig7withtable2
field = 1
D2/3: drv = sqlite db =
$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db
D3/3: Vect_subst_var(): in =
$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db, map =
vinasciig7withtable2, mapset = g7
D3/3: -> C:\gisdata\grassdata/nc_spm_08/g7/sqlite.db
D3/3: db_start_driver_open_database():
drvname = sqlite, dbname =
D2/3: dbDbmscap(): opendir [C:\Program
Files\GRASS-70-SVN\driver\db\]
D3/3: win_spawn: args = C:\windows\system32\cmd.exe /c
""C:\Program Files\GRASS-70-SVN\driver\db\sqlite.exe""
D3/3:
db_driver_open_database()
D3/3: name = 'C:\gisdata\grassdata/nc_spm_08/g7/sqlite.db'
D2/3: name2 = 'C:\gisdata\grassdata/nc_spm_08/g7/sqlite.db'
D3/3: execute: BEGIN
Column: 1 type: double
Column: 2 type: double
Column: 3 type: integer
Column: 4 type: string length: 13
D3/3: Field number <1>, name <(null)>
D3/3: Vect_check_dblink: field 1, name vinasciig7withtable2
D1/3: Vect_write_dblinks(): map = vinasciig7withtable2,
mapset = g7
D1/3: dbln file: C:\gisdata\grassdata/nc_spm_08/g7/vector/vi
nasciig7withtable2/dbln
D1/3: 1/vinasciig7withtable2|vinasciig7withtable2|cat|$GISDB
ASE/$LOCATION_NAME/$MAPSET/sqlite.db|sqlite
D1/3: Dblinks written
D3/3: create table vinasciig7withtable2 ( cat integer, dbl_1
double precision, dbl_2 double precision, int_1 integer,
str_1 varchar(13) )
D3/3: execute: create table vinasciig7withtable2 ( cat
integer, dbl_1 double precision, dbl_2 double precision,
int_1 integer, str_1 varchar(13) )
D3/3: db__create_index()
D3/3: SQL: create unique index vinasciig7withtable2_cat on
vinasciig7withtable2 ( cat )
mapset = g7
mapset = g7
Importiere Punkte...
D3/3: Vect_write_line(): name = vinasciig7withtable2, format
= 0, level = 1
D3/3: insert into vinasciig7withtable2 values ( 1,
620856.95858763, 230066.38313211, 1, 'Morrisville')
D3/3: execute: insert into vinasciig7withtable2 values ( 1,
= 0, level = 1
D3/3: insert into vinasciig7withtable2 values ( 2,
625331.91859749, 229990.82160763, 2, 'Morrisville')
D3/3: execute: insert into vinasciig7withtable2 values ( 2,
= 0, level = 1
D3/3: insert into vinasciig7withtable2 values ( 3,
615797.66547487, 213363.99261983, 3, 'Apex')
D3/3: execute: insert into vinasciig7withtable2 values ( 3,
= 0, level = 1
D3/3: insert into vinasciig7withtable2 values ( 4,
623113.71424165, 219859.06222161, 4, 'Apex')
D3/3: execute: insert into vinasciig7withtable2 values ( 4,
= 0, level = 1
D3/3: insert into vinasciig7withtable2 values ( 5,
627926.28432081, 203208.6160536, 5, 'Fuquay-Varina')
D3/3: execute: insert into vinasciig7withtable2 values ( 5,
D3/3: execute: insert into vinasciig7withtable2 values ( 67,
651050.34524882, 232036.68777768, 67, 'Raleigh')
= 0, level = 1
D3/3: insert into vinasciig7withtable2 values ( 68,
649833.80593756, 219907.29347997, 68, 'Raleigh')
D3/3: execute: insert into vinasciig7withtable2 values ( 68,
= 0, level = 1
D3/3: insert into vinasciig7withtable2 values ( 69,
622136.90859827, 220306.42922513, 69, 'Apex')
D3/3: execute: insert into vinasciig7withtable2 values ( 69,
= 0, level = 1
D3/3: insert into vinasciig7withtable2 values ( 70,
625889.8783814, 211478.01839282, 70, 'Holly Springs')
D3/3: execute: insert into vinasciig7withtable2 values ( 70,
= 0, level = 1
D3/3: insert into vinasciig7withtable2 values ( 71,
623658.64334595, 209478.24330292, 71, 'Holly Springs')
D3/3: execute: insert into vinasciig7withtable2 values ( 71,
D3/3: execute: COMMIT
D3/3: db_close_database()
Fülle Tabelle...
D2/3: db_close_database() result: 0 (0 means success)
D2/3: db_shutdown_driver() failed
ERROR: Could not close attribute table. The DBMI driver did not accept all
attributes.
also here again the following message about the dbmi-driver:
attributes.
'''BUT''' the ascii-vector-data (also the table-data) is imported, you can
add the imported data in the map display and are able to open the
attribute table in the attribute table manager.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159#comment:11>
