[GRASS-dev] Re: [GRASS GIS] #1159: v.in.ascii fails with long text file in WinGRASS-6.4.0-1
GRASS GIS trac at osgeo.org
Mon Sep 20 15:12:37 EDT 2010
 Reporter:  lponti      |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  6.4.1
Component:  Vector      |     Version:  6.4.0
 Keywords:  v.in.ascii  |    Platform:  MSWindows 7
      Cpu:  x86-32      |
Comment(by glynn):
 Replying to [comment:10 hellik]:
 > My test mentioned above was in WinGrass65.
 This issue applies to all branches and to the 6.4.0 release. And to RC7;
 RC6 was the last version to use _spawnl(). All later versions are likely
 to be broken on Windows, where db_shutdown_driver() will report failure.
 The driver itself should terminate correctly, but the client will believe
 that it failed.
 Of the many calls to db_shutdown_driver(), only one actually checks the
 return code. That is the one in db_close_database_shutdown_driver(), which
 will return DB_FAILED.
 Of the many calls to db_close_database_shutdown_driver(), only one
 actually checks the return code, and that one is in v.in.ascii.
 The net result is that v.in.ascii terminates with a fatal error rather
 than calling Vect_build() and Vect_close().
 This can be "fixed" by removing the check of the return code. We should
 actually fix db_shutdown_driver(), but in the meantime, we may as well get
 v.in.ascii working (and why should v.in.ascii be any different to all of
 the other modules?)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159#comment:12>
