[GRASS-dev] Re: [GRASS GIS] #1159: v.in.ascii points import fails in WinGRASS-6.4.0-1 (was: v.in.ascii fails with long text file in WinGRASS-6.4.0-1)
GRASS GIS trac at osgeo.org
Mon Sep 20 23:52:43 EDT 2010
 Reporter:  lponti      |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  6.4.1
Component:  Vector      |     Version:  6.4.0
 Keywords:  v.in.ascii  |    Platform:  MSWindows 7
      Cpu:  x86-32      |
Changes (by hamish):
  * priority:  normal => blocker
Comment:
 even
 echo "10|10|abcd" | v.in.ascii out=test
 fails for WinGrass (tested in 6.5svn). agree to disable the test while we
 find a solution in the dev branches; suggest to replace the 6.4.0.exe
 WinGrass installer link ASAP with a nightly build after that is done,
 until we release 6.4.1 (which we should start planning for pretty soon).
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159#comment:13>
