[GRASS-dev] Re: [GRASS GIS] #1166: r.tileset: projection string
munching on wingrass
trac at osgeo.org
Sun Sep 19 06:10:35 EDT 2010
#1166: r.tileset: projection string munching on wingrass
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Default | Version: svn-develbranch6
Keywords: r.tileset, wingrass | Platform: MSWindows XP
Cpu: x86-64 |
Comment(by hamish):
Replying to [comment:4 hellik]:
> I've tested r.in.wms in WinGrass64 and r.in.gdalwarp/gdalwarp
> couldn't find the needed gcs.csv etc. files.
fwiw, r.in.wms is known to be partly not working in 6.4.0 wingrass, pls
use latest 6.5svn for testing that.
also gdalwarp will fail if the target SRS contains a NTv2 +nadgrids file
path with a space in it. No known solution (see thread on PROJ4 mailing
list).
The Location wizard seems to be able to find the share/epsg file, so some
of the support files must be getting copied...
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1166#comment:5>
