[GRASS-dev] v.rast.stats
Markus Metz
markus.metz.giswork at googlemail.com
Mon Sep 20 03:21:20 EDT 2010
Dylan Beaudette wrote:
> Hi,
> There are times were dumping the results from v.rast.stats to a file is more
> efficient than uploading to an attribute table. Would anyone be interested in
> a slight modification to v.rast.stats that would allow this?
This functionality already exists in r.univar.zonal (grass-addons, C
module) which should IMHO be used by v.rast.stats in g7 because it's
much faster for vectors with many areas.
Markus M
> Also, would it
> be worth putting in the time to implement this in sh, when python is the
> future? Therefore, would it make sense to replace the sh version in GRASS65
> with a modified version of the python script from GRASS7?
> Dylan
> Dylan Beaudette
> Soil Resource Laboratory
> http://casoilresource.lawr.ucdavis.edu/
> University of California at Davis
> 530.754.7341
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
