[GRASS-dev] v.rast.stats
Dylan Beaudette debeaudette at ucdavis.edu
Mon Sep 20 12:05:12 EDT 2010
On Monday 20 September 2010, Markus Metz wrote:
> Dylan Beaudette wrote:
> > Hi,
> > There are times were dumping the results from v.rast.stats to a file is
> > more efficient than uploading to an attribute table. Would anyone be
> > interested in a slight modification to v.rast.stats that would allow
> > this?
> This functionality already exists in r.univar.zonal (grass-addons, C
> module) which should IMHO be used by v.rast.stats in g7 because it's
> much faster for vectors with many areas.
> Markus M
Thanks Markus, this looks like the way to go. I'll give it a try on GRASS65
and see how it works for our application.
Cheers,
Dylan
> > Also, would it
> > be worth putting in the time to implement this in sh, when python is the
> > future? Therefore, would it make sense to replace the sh version in
> > GRASS65 with a modified version of the python script from GRASS7?
> > Dylan
> > Dylan Beaudette
> > Soil Resource Laboratory
> > http://casoilresource.lawr.ucdavis.edu/
> > University of California at Davis
> > 530.754.7341
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
Dylan Beaudette
530.754.7341
