[GRASS-dev] [GRASS GIS] #1168: r.surf.contour: use floating point
for elevation values
trac at osgeo.org
Mon Sep 20 11:10:56 EDT 2010
#1168: r.surf.contour: use floating point for elevation values
Reporter: mmetz | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 6.5.0
Component: Raster | Version: 6.4.0
Keywords: | Platform: All
Cpu: All |
r.surf.contour currently stores elevation values as integer because
historically there was no support for fp in grass rasters. Time to change
that, eliminating the need for the workaround described in wiki [1]. The
change required is small, thus milestone 6.5.
[1] http://grass.osgeo.org/wiki/Contour_lines_to_DEM#r.surf.contour
Ticket URL: <http://trac.osgeo.org/grass/ticket/1168>
