[GRASS-dev] Re: [GRASS GIS] #1167: wx location wizard: proj4 terms fall off edge of window
GRASS GIS trac at osgeo.org
Wed Sep 22 05:07:25 EDT 2010
 Reporter:  hamish               |       Owner:  martinl
     Type:  defect               |      Status:  new
 Priority:  minor                |   Milestone:  6.4.1
Component:  Startup              |     Version:  svn-develbranch6
 Keywords:  wx, location wizard  |    Platform:  Linux
      Cpu:  x86-64               |
Comment(by hamish):
 Replying to [comment:1 martinl]:
 > In r43567 is projstring wrapped based on spaces. Is it
 > enough for this ticket from your point of view?
 yes, that is very nice, thank you.
 similar issue: define location by PRJ or WKT file falls off the right hand
 side of the window in the same way if the path is very long (just happened
 to me today). is there a way to wrap the string after it gets to a dirsep
 past column 60-something?
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1167#comment:2>
