[GRASS-dev] Re: [GRASS GIS] #718: r.li forgets mask/illegal filename
trac at osgeo.org
Mon Sep 20 17:13:58 EDT 2010
Reporter: kyngchaos | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: 6.4.0 RCs
Keywords: r.li, smp | Platform: All
Cpu: All |
Comment(by kyngchaos):
I had trouble remembering what I did for the r.li.setup part. I finally
downloaded the NC data to try hamish's conf's.
The first one works fine, but hamish didn't have a problem with that
either.
The next one gives an error (all jumbled from the multiple workers) and
hangs (must ctl-c to exit):
> r.li.shannon map=landclass96 conf=test_conf2 out=test_shannon2
ERROR: ERROR: ProgramERROR: error,Program worker()Program
toReceive.type=0 error,
error, worker()worker() toReceive.type=24184648toReceive.type=0
In 32bit mode, it finishes with no error, but there is also no output.
Patch density using the first conf seems to work in both 64 and 32bit
modes, though there are bands of what looks like noise, in different
places between 32 and 64bit. But I get the same error/hang on 64bit and
no output on 32bit using the other conf.
Ticket URL: <https://trac.osgeo.org/grass/ticket/718#comment:24>
