[GRASS-dev] swig
Soeren Gebbert soerengebbert at googlemail.com
Tue Sep 21 03:19:56 EDT 2010
Hello Mohammed,
maybe you can use the vtk-grass-bridge? The vtk-grass-bridge is a
VTK/C++ wrapper around grass gis to provide direct access to grass
library in C++, Python and Java. So many GRASS GIS library functions
are available using this interface in Python, currently  the raster-,
vector-, voxel-, gis- and dbmi-libraries.
Have a look at:
http://code.google.com/p/vtk-grass-bridge/
Here are some unit tests which show how to handle raster, vector and
the dbmi interface using the vtk-grass-bridge:
This is a test for raster map read - write access:
http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Raster/Testing/Python/GRASSRasterMapReaderWriterTest.py
This is a test for vector read access:
http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Vector/Testing/Python/GRASSVectorMapTopoReader.py
This test shows how to use the dbmi interface:
http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/DBMI/Testing/Python/vtkGRASSDbmiInterfaceReaderTest.py
This test shows the command line interface functionality:
http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Common/Testing/Python/GRASSModuleTest.py
Here the C++ code of a VTK class which reads grass vector maps as
vtkPolyData and adds vector table columns as cell data.
I hope this may help you a bit. But i must warn you, GRASS GIS library
and so the vtk-grass-bridge is not designed to implement persistent
applications like a GUI using the library functions directly.
Feel free to ask any questions about the vtk-grass-bridge.
Best regards
Soeren
2010/9/21 Mohammed Rashad <mohammedrashadkm at gmail.com>:
> Hi all,
> sorry for off-topic. kindly forgive me
> I would like to make a python gui toolkit based on FOX C++ Gui toolkit. I
> had some basic knowledge in swig based on tutorials given in
> the swig.org homepage. But my knowledge is not enough to make swig files for
> a whole GUI toolkit.
> So anyone please give me some links on making swig interface for python.
> Is there any good books for the making of swig interface. Treat me as a
> newbie to swig.
> Is there any users who develop swig interface for python based on GRASS
> C/C++ library?
> All I need is good start on making swig interfaces
> Any help will be greatly appreciated.
> Thanks in advance.
> Rashad
> Rashad
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
