[GRASS-dev] Review of the Advanced GRASS command console
Tim Michelsen timmichelsen at gmx-topmail.de
Tue Sep 21 14:53:20 EDT 2010
Hello,
here are some observations on the Advanced GRASS command console (GRASS
7) and code completion in internal console:
- layer name ompletion (CTRL+SPACE) should only happen when a parameter
is pressed requiring a layer name as input (input=, map=)
- the command synopsis could be displayed in the background
- a IPython mode would be good where Ipython would be started with a
GRASS profile
I can explain more if you do not understand or I am not detailed enough.
Regards,
Timmie
