[GRASS-dev] Re: [GRASS GIS] #1173: v.surf.rst: bug in handling
Output deviations vector point file
trac at osgeo.org
Wed Sep 22 06:25:54 EDT 2010
#1173: v.surf.rst: bug in handling Output deviations vector point file
Reporter: mmetz | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Vector | Version: svn-releasebranch64
Keywords: vector, rst library | Platform: All
Cpu: All |
Comment(by glynn):
Replying to [ticket:1173 mmetz]:
> A possible solution could be to change IL_init_params_2d
If you're going to do that, can you finish the job and create a sane
interface for initialisation. A single function with 40-odd parameters
isn't particularly convenient.
I've been getting this warning:
main.c:596: warning: passing argument 41 of 'IL_init_params_2d' from
incompatible pointer type
for as long as I can remember. A while back, I went through the code
fixing warnings. When I got to that one, it was a case of "argument 41 is
... 1, 2, 3, 4, ... ah, forget it" and I moved on to the next one.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1173#comment:1>
