[GRASS-dev] Re: [GRASS GIS] #1173: v.surf.rst: bug in handling
Output deviations vector point file
trac at osgeo.org
Wed Sep 22 08:07:34 EDT 2010
#1173: v.surf.rst: bug in handling Output deviations vector point file
Reporter: mmetz | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Vector | Version: svn-releasebranch64
Keywords: vector, rst library | Platform: All
Cpu: All |
Comment(by mmetz):
Replying to [comment:1 glynn]:
> Replying to [ticket:1173 mmetz]:
> > A possible solution could be to change IL_init_params_2d
> If you're going to do that, can you finish the job and create a sane
interface for initialisation. A single function with 40-odd parameters
isn't particularly convenient.
Not likely that I'm going to do that, I don't really understand the RST
library, currently don't have time to dive into it, and these 40-odd
function arguments (not only for IL_init_params_2d) are scaring me off...
I have created the ticket as a general reminder in the hope that it will
be fixed at some stage (hopefully for grass7.0 stable). Or this deviation
option gets kicked out if unused.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/1173#comment:2>
