[GRASS-dev] Re: [GRASS GIS] #1159: v.in.ascii points import fails in WinGRASS-6.4.0-1
GRASS GIS trac at osgeo.org
Wed Sep 22 14:37:01 EDT 2010
 Reporter:  lponti      |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  6.4.1
Component:  Vector      |     Version:  6.4.0
 Keywords:  v.in.ascii  |    Platform:  MSWindows 7
      Cpu:  x86-32      |
Comment(by hellik):
 Replying to [comment:19 hamish]:
 > eye be blind. louder version of debug message applied to trunk in r43610
 so it is not forgotten.
 Glynn suggested also following patch which was confirmed as working by
 Luigi:
 --- vector/v.in.ascii/in.c~     2010-09-04 16:31:59.000000000 +0100
 +++ vector/v.in.ascii/in.c      2010-09-21 08:57:12.000000000 +0100
 @@ -519,8 +519,7 @@
         if (driver) {
             G_message(_("Populating table..."));
             db_commit_transaction(driver);
 -           if(db_close_database_shutdown_driver(driver) == DB_FAILED)
 -               G_fatal_error(_("Could not close attribute table. The DBMI
 driver did not accept all attributes"));
 +           db_close_database_shutdown_driver(driver);
         fclose(tmpascii);
 (see:
 http://lists.osgeo.org/pipermail/grass-user/2010-September/057976.html
 http://lists.osgeo.org/pipermail/grass-user/2010-September/057985.html)
 maybe I've missed something (I can't see this in any branches nor in
 trunk)?
 should this also be applied?
 best regards
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159#comment:20>
