[GRASS-dev] Re: [GRASS GIS] #1159: v.in.ascii points import fails in
 WinGRASS-6.4.0-1
    trac at osgeo.org
    Wed Sep 22 17:08:29 EDT 2010
#1159: v.in.ascii points import fails in WinGRASS-6.4.0-1
 Reporter:  lponti      |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  6.4.1
Component:  Vector      |     Version:  6.4.0
 Keywords:  v.in.ascii  |    Platform:  MSWindows 7
      Cpu:  x86-32      |
Comment(by glynn):
 Replying to [comment:20 hellik]:
 > Glynn suggested also following patch which was confirmed as working by
 Luigi:
 > maybe I've missed something (I can't see this in any branches nor in
 trunk)?
 > should this also be applied?
 It's an alternative to r43610, r43550, and r43601. It makes v.in.ascii
 consistent with other modules, none of which check the return code from
 db_close_database_shutdown_driver().
Ticket URL: <http://trac.osgeo.org/grass/ticket/1159#comment:21>
