[GRASS-dev] Re: [GRASS GIS] #1174: Set zoom to/from computational
region in display map does not work
trac at osgeo.org
Fri Sep 24 12:15:04 EDT 2010
#1174: Set zoom to/from computational region in display map does not work
Reporter: frankie | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: Tcl/Tk | Version: 6.4.0
Keywords: | Platform: Linux
Cpu: All |
Comment(by mlennert):
Replying to [ticket:1174 frankie]:
> It is quite easy to check. Simply change resolution and try to zoom at
the new level. It is ignored.
Doing
- set computational region extents to match display
- g.region -a res=500
- zoom to computational display
- g.region -a res=10000
works for me. Are you sure you are using the constrained display mode ?
(Just to confirm: This is in the old tcltk GUI, or ?).
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1174#comment:1>
