[GRASS-dev] Re: [GRASS GIS] #1174: Set zoom to/from computational
region in display map does not work
trac at osgeo.org
Mon Sep 27 09:14:28 EDT 2010
#1174: Set zoom to/from computational region in display map does not work
Reporter: frankie | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: Tcl/Tk | Version: 6.4.0
Keywords: | Platform: Linux
Cpu: All |
Comment(by frankie):
It is an error in gis.m. Let do what follows in spearfish:
* Load vegcover in layer tree.
* View it in display map at default res (30m)
* Change resolution to 500m by g.region (menu or command line)
* Then -> Zoom display to computational region. It does not change
resolution in the display map. Up to 6.2 that was working.
I do not see any reason because one has to set computational region to
match display, as you suggest, before that. Also note I'm using Tcl/Tk 8.4
which is the default in Debian sid/squeeze and 6.4.0 final.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1174#comment:2>
