[GRASS-dev] Re: [GRASS GIS] #1178: WinGrass: g.extension - problem
with path to $GISBASE
trac at osgeo.org
Sun Sep 26 06:01:45 EDT 2010
#1178: WinGrass: g.extension - problem with path to $GISBASE
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: Installation | Version: svn-releasebranch64
Keywords: wingrass, g.extension, path, installation, addons | Platform: MSWindows Vista
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:1 neteler]:
> Please add " -x" (without quotes to the first line of g.extension and
run again to
> understand how
> cd "$TMPDIR/$MODULE"
> g.message message="Compiling <${MODULE}>..."
> make MODULE_TOPDIR="$GISBASE"
> if [ $? -ne 0 ] ; then
> is running.
with added -x in the first line:
Welcome to GRASS 6.4.1svn (2010)
GRASS homepage: http://grass.osgeo.org/
This version running thru: Bourne Shell (/bin/sh)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
GRASS 6.4> g.extension extension=r.stream.order
+ '[' -z '/C/Program Files/GRASS-64-SVN' ']'
+ '[' extension=r.stream.order '!=' @ARGS_PARSED@ ']'
+ exec g.parser '/C/Program Files/GRASS-64-SVN/scripts/g.extension'
extension=r .stream.order
Fetching <r.stream.order> from GRASS-Addons SVN (be patient)...
A r.stream.order\main.c
A r.stream.order\description.html
A r.stream.order\global.h
A r.stream.order\io.c
A r.stream.order\order.c
A r.stream.order\Makefile
Checked out revision 43689.
Compiling <r.stream.order>...
Makefile:12: c:/Program: No such file or directory
Makefile:12: Files/GRASS-64-SVN/include/Make/Module.make: No such file or
direc tory
make: *** No rule to make target
`Files/GRASS-64-SVN/include/Make/Module.make'.
Stop.
FEHLER: Compilation failed, sorry. Please check above error messages.
rm: cannot remove directory
`C:\\gisdata\\grassdata/wgs84gc/user1/.tmp/3488.0/r
.stream.order': Permission denied
GRASS 6.4>
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1178#comment:3>
