[GRASS-dev] Re: [GRASS GIS] #1178: WinGrass: g.extension - problem with path to $GISBASE
GRASS GIS trac at osgeo.org
Sun Sep 26 06:09:07 EDT 2010
 Reporter:  hellik                                             |       Owner:  grass-dev@…
     Type:  defect                                             |      Status:  new
 Priority:  major                                              |   Milestone:  6.4.1
Component:  Installation                                       |     Version:  svn-releasebranch64
 Keywords:  wingrass, g.extension, path, installation, addons  |    Platform:  MSWindows Vista
      Cpu:  x86-32                                             |
Comment(by hellik):
 Replying to [comment:2 hamish]:
 > the problem is certainly on that line of the script:
 >   make MODULE_TOPDIR="$GISBASE"
 > but I don't know how to fix it. (maybe g.dirseps or `sed 's/ /\\ /g'` if
 Windows is detected?)
 > Hamish
 > ps- while harmlessly used a lot in the script, ${curly} brackets do not
 actually protect spaces in file or path names, just variable names from
 following characters which would otherwise continue the variable name, or
 for readability.
 I've tried it now with Grass64svn living in
 C:\OSGeo4W\apps\grass\grass-6.4.1svn:
 GRASS 6.4> g.extension extension=r.stream.order
 which: wget: unknown command
 Fetching <r.stream.order> from GRASS-Addons SVN (be patient)...
 A    r.stream.order\main.c
 A    r.stream.order\description.html
 A    r.stream.order\global.h
 A    r.stream.order\io.c
 A    r.stream.order\order.c
 A    r.stream.order\Makefile
 Checked out revision 43689.
 Compiling <r.stream.order>...
 test -d OBJ.i686-pc-mingw32 || mkdir -p OBJ.i686-pc-mingw32
 gcc -I/c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32/include
 -I/c/OSGeo4W/a
 pps/gdal-16/include -I/c/OSGeo4W/include -g -O2
 -I/c/OSGeo4W/apps/gdal-16/incl
 ude -I/c/OSGeo4W/include  -I/c/OSGeo4W/include
 -DPACKAGE=\""grassmods"\"  -I
 /c/osgeo4w/usr/src/grass64svn/dist.i686-pc-mingw32/include -o OBJ.i686-pc-
 mingw
 32/io.o -c io.c
 io.c:1:27: grass/glocale.h: No such file or directory
 In file included from io.c:2:
 global.h:5:23: grass/gis.h: No such file or directory
 global.h:6:24: grass/Vect.h: No such file or directory
 global.h:7:24: grass/dbmi.h: No such file or directory
 global.h:80: error: syntax error before '*' token
 global.h:81: error: syntax error before '*' token
 global.h:93: error: syntax error before '*' token
 global.h:93: warning: data definition has no type or storage class
 global.h:94: error: syntax error before '*' token
 global.h:94: warning: data definition has no type or storage class
 io.c: In function `open_raster':
 io.c:8: error: storage size of 'cellhd' isn't known
 io.c:10: warning: assignment makes pointer from integer without a cast
 io.c:16: error: `CELL_TYPE' undeclared (first use in this function)
 io.c:16: error: (Each undeclared identifier is reported only once
 io.c:16: error: for each function it appears in.)
 io.c:26: error: invalid use of undefined type `struct Cell_head'
 io.c: In function `create_base_maps':
 io.c:37: error: `CELL' undeclared (first use in this function)
 io.c:37: error: `r_dirs' undeclared (first use in this function)
 io.c:37: error: `r_streams' undeclared (first use in this function)
 io.c:38: error: `DCELL' undeclared (first use in this function)
 io.c:38: error: `r_accum' undeclared (first use in this function)
 io.c:47: error: syntax error before ')' token
 io.c:48: error: syntax error before ')' token
 io.c:50: error: syntax error before ')' token
 io.c:52: error: syntax error before ')' token
 io.c:53: error: syntax error before ')' token
 io.c:55: error: syntax error before ')' token
 io.c:62: warning: assignment makes pointer from integer without a cast
 io.c:63: warning: assignment makes pointer from integer without a cast
 io.c:73: error: syntax error before ')' token
 io.c: In function `stream_number':
 io.c:120: error: `CELL' undeclared (first use in this function)
 io.c:120: error: syntax error before "c_min"
 io.c:121: error: storage size of 'stream_range' isn't known
 io.c:124: warning: assignment makes pointer from integer without a cast
 io.c:126: error: `c_min' undeclared (first use in this function)
 io.c:126: error: `c_max' undeclared (first use in this function)
 io.c: In function `write_maps':
 io.c:136: error: `CELL' undeclared (first use in this function)
 io.c:136: error: `strahler_buf' undeclared (first use in this function)
 io.c:136: error: `shreeve_buf' undeclared (first use in this function)
 io.c:136: error: `hack_buf' undeclared (first use in this function)
 io.c:136: error: `horton_buf' undeclared (first use in this function)
 io.c:136: error: `topo_buf' undeclared (first use in this function)
 io.c:138: error: storage size of 'history' isn't known
 io.c:142: error: `CELL_TYPE' undeclared (first use in this function)
 io.c: In function `create_table':
 io.c:285: error: `dbConnection' undeclared (first use in this function)
 io.c:285: error: syntax error before "conn"
 io.c:286: error: `dbDriver' undeclared (first use in this function)
 io.c:286: error: `driver' undeclared (first use in this function)
 io.c:287: error: `dbHandle' undeclared (first use in this function)
 io.c:287: error: syntax error before "handle"
 io.c:288: error: `dbString' undeclared (first use in this function)
 io.c:334: error: `db_sql' undeclared (first use in this function)
 io.c:335: error: `val_string' undeclared (first use in this function)
 io.c:336: error: `table_name' undeclared (first use in this function)
 io.c:337: error: `handle' undeclared (first use in this function)
 io.c:341: error: `conn' undeclared (first use in this function)
 io.c:383: error: `DB_OK' undeclared (first use in this function)
 io.c:393: error: `DB_PRIV_SELECT' undeclared (first use in this function)
 io.c:393: error: `DB_GROUP' undeclared (first use in this function)
 io.c:393: error: `DB_PUBLIC' undeclared (first use in this function)
 make: *** [OBJ.i686-pc-mingw32/io.o] Error 1
 FEHLER: Compilation failed, sorry. Please check above error messages.
 rm: cannot remove directory
 `C:\\gisdata\\grassdata/wgs84gc/user1/.tmp/3648.0/r
 .stream.order': Permission denied
 compiling is starting, but a lot of errors (maybe r.stream.order isn't for
 Grass64?)
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1178#comment:4>
