[GRASS-dev] Re: [GRASS GIS] #820: r.in.wms doesn't work in WinGRASS
installer distribution
trac at osgeo.org
Sun Sep 26 10:41:44 EDT 2010
#820: r.in.wms doesn't work in WinGRASS installer distribution
Reporter: ddalimonte | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Projections/Datums | Version: svn-releasebranch64
Keywords: r.in.wms, wingrass, cs2cs | Platform: MSWindows XP
Cpu: Unspecified |
Comment(by msieczka):
Replying to [comment:36 hellik]:
> Replying to [comment:35 msieczka]:
> > Replying to [comment:34 hamish]:
> > > there is also r.tileset, cs2cs, and gdalwarp issues to consider.
> > > it is getting better, but please just leave the backporting alone
for now..
> > Maybe drop r.in.wms in Win GRASS 6.4.1? Bugs are known, not going to
be fixed, so no point in frustrating the user?
> with the recent fixes for GDAL_DATA and PROJ_LIB variables needed in
windows and some backports from Grass65 to Grass64svn, r.in.wms should now
working also in WinGrass6.4.1 (tested with the examples in the manpages in
WinGrass6.4.1 in the nc-location: all are working)
I have Installed
http://josef.fsv.cvut.cz/wingrass/grass64/WinGRASS-6.4.SVN-r43540-1-Setup.exe
and overwritten respective files in C:\Program Files\GRASS-64-SVN\scripts
with most recent stuff from
https://svn.osgeo.org/grass/grass/branches/releasebranch_6_4/scripts/r.in.wms/.
In spearfish60 an error crops out:
GRASS 6.4> g.region rast=elevation.dem -ag
n=4928000
s=4914020
w=590010
e=609000
nsres=30
ewres=30
rows=466
cols=633
cells=294978
GRASS 6.4> r.in.wms layers=global_mosaic
mapserver=http://wms.jpl.nasa.gov/wms.
cgi output=wms_global_mosaic --o
which: wget: unknown command
Calculating tiles
Rel. 4.7.1, 23 September 2009
<cs2cs.exe>:
projection initialization failure
cause: Unknown error
program abnormally terminated
ERROR: Problem running cs2cs. <Using to definition: init=epsg:4326 >
ERROR: r.tileset failure
ERROR: wms.request failure
Ticket URL: <http://trac.osgeo.org/grass/ticket/820#comment:37>
