[GRASS-dev] Re: [GRASS GIS] #820: r.in.wms doesn't work in WinGRASS installer distribution
GRASS GIS trac at osgeo.org
Sun Sep 26 11:16:48 EDT 2010
 Reporter:  ddalimonte                 |       Owner:  grass-dev@…
     Type:  defect                     |      Status:  new
 Priority:  major                      |   Milestone:  6.4.0
Component:  Projections/Datums         |     Version:  svn-releasebranch64
 Keywords:  r.in.wms, wingrass, cs2cs  |    Platform:  MSWindows XP
      Cpu:  Unspecified                |
Comment(by hellik):
 Replying to [comment:37 msieczka]:
 > Replying to [comment:36 hellik]:
 > > Replying to [comment:35 msieczka]:
 > > > Replying to [comment:34 hamish]:
 > > > > there is also r.tileset, cs2cs, and gdalwarp issues to consider.
 > > > > it is getting better, but please just leave the backporting alone
 for now..
 > > > Maybe drop r.in.wms in Win GRASS 6.4.1? Bugs are known, not going to
 be fixed, so no point in frustrating the user?
 > > with the recent fixes for GDAL_DATA and PROJ_LIB variables needed in
 windows and some backports from Grass65 to Grass64svn, r.in.wms should now
 working also in WinGrass6.4.1 (tested with the examples in the manpages in
 WinGrass6.4.1 in the nc-location: all are working)
 > I have Installed
 http://josef.fsv.cvut.cz/wingrass/grass64/WinGRASS-6.4.SVN-r43540-1-Setup.exe
 and overwritten respective files in C:\Program Files\GRASS-64-SVN\scripts
 with most recent stuff from
 https://svn.osgeo.org/grass/grass/branches/releasebranch_6_4/scripts/r.in.wms/.
 > In spearfish60 an error crops out:
 > GRASS 6.4> g.region rast=elevation.dem -ag
 > n=4928000
 > s=4914020
 > w=590010
 > e=609000
 > nsres=30
 > ewres=30
 > rows=466
 > cols=633
 > cells=294978
 > GRASS 6.4> r.in.wms layers=global_mosaic
 mapserver=http://wms.jpl.nasa.gov/wms.
 > cgi output=wms_global_mosaic --o
 > which: wget: unknown command
 > Calculating tiles
 > Rel. 4.7.1, 23 September 2009
 > <cs2cs.exe>:
 > projection initialization failure
 > cause: Unknown error
 > program abnormally terminated
 > ERROR: Problem running cs2cs. <Using to definition: init=epsg:4326 >
 > ERROR: r.tileset failure
 > ERROR: wms.request failure
 you need also:
 r43520
 r43542
 that means add GDAL_DATA and PROJ_LIB variable in following files
 C:\Program Files\GRASS-64-SVN\grass64svn.bat
 C:\Program Files\GRASS-64-SVN\bin\grass64svn
 in grass64svn.bat
 rem Set GDAL_DATA
 set GDAL_DATA=%GRASSDIR%\etc\ogr_csv
 rem Set PROJ_LIB
 set PROJ_LIB=%GRASSDIR%\proj
 and in grass64svn
 # Set the GDAL_DATA variable
 GDAL_DATA="C:\Program Files\GRASS-64-SVN\etc\ogr_csv"
 export GDAL_DATA
 # Set the PROJ_LIB variable
 PROJ_LIB="C:\Program Files\GRASS-64-SVN\proj"
 export PROJ_LIB
 if you want I can you give WinGRASS-6.4.SVN-r43468-1-Setup.exe (self
 compiled from yesterday) for testing?
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/820#comment:38>
