[GRASS-dev] Re: [GRASS GIS] #959: r.surf.contour. Resulting range of values has an incorrect 0 minimum.
GRASS GIS trac at osgeo.org
Tue Sep 28 00:30:20 EDT 2010
 Reporter:  clerici               |       Owner:  grass-dev@…
     Type:  defect                |      Status:  new
 Priority:  normal                |   Milestone:  6.4.1
Component:  Raster                |     Version:  svn-releasebranch64
 Keywords:  r.surf.contour, NULL  |    Platform:  Linux
      Cpu:  Unspecified           |
Comment(by hamish):
 > Also fixed for 6.4.1 in 43605. I regard it as a change that
 > should have happened several years ago.
 sure; all backports need thorough testing, so:
 tested r.surf.contour in 6.5svn using NC dataset commands from
 http://grass.osgeo.org/wiki/Contour_lines_to_DEM#r.surf.contour
 searching for artifacts in the derivative layers,
 r.slope.aspect elev=elev.1mcont.surf slope=elev.1mcont.surf.slope \
   aspect=elev.1mcont.surf.aspect pcurv=elev.1mcont.surf.pcurv \
   tcurv=elev.1mcont.surf.tcurv
 the profile curvature map highlights the "thatched roof" effect at contour
 lines as before. but all in all it's pretty good and nothing that a 5x5
 r.neighbors smoothing can't clean up.
 integer 0 contour levels tested ok too:
 r.mapcalc "elev.1mcont.sealevel = int(elev.1mcont - 115)
 remaining in CELL-only is r.surf.idw; ''r.surf.idw is much faster than
 r.surf.idw2 but does not create floating-point maps directly. Otherwise
 the module output is practically identical.''
 see  http://grass.osgeo.org/wiki/Contour_lines_to_DEM#r.surf.idw
 thanks,
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/959#comment:4>
