[GRASS-dev] Re: [GRASS GIS] #959: r.surf.contour. Resulting range of values has an incorrect 0 minimum.
GRASS GIS trac at osgeo.org
Tue Sep 28 02:38:00 EDT 2010
 Reporter:  clerici               |       Owner:  grass-dev@…
     Type:  defect                |      Status:  new
 Priority:  normal                |   Milestone:  6.4.1
Component:  Raster                |     Version:  svn-releasebranch64
 Keywords:  r.surf.contour, NULL  |    Platform:  All
      Cpu:  All                   |
Changes (by mmetz):
  * platform:  Linux => All
  * cpu:  Unspecified => All
Comment:
 Replying to [comment:4 hamish]:
 > the profile curvature map highlights the "thatched roof" effect at
 contour lines as before.
 The "thatched roof" effect is caused by the the interpolation method
 (inverse distance weighing) used by r.surf.contour.
 IMHO, interpolating surfaces from contour lines should nowadays be a last
 resort to generate a surface when no other data (grids or point clouds)
 are available.
 Thanks for additional testing,
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/959#comment:5>
