[GRASS-dev] Re: [GRASS GIS] #820: r.in.wms doesn't work in WinGRASS installer distribution
GRASS GIS trac at osgeo.org
Tue Sep 28 14:40:32 EDT 2010
 Reporter:  ddalimonte                 |       Owner:  hamish
     Type:  defect                     |      Status:  new
 Priority:  major                      |   Milestone:  6.4.1
Component:  Projections/Datums         |     Version:  svn-releasebranch64
 Keywords:  r.in.wms, wingrass, cs2cs  |    Platform:  MSWindows XP
      Cpu:  All                        |
Changes (by msieczka):
  * cpu:  Unspecified => All
Comment:
 Replying to [comment:40 hellik]:
 > the nightly builds seems to be broken at the moment. please test then
 within the nc-sample-dataset and the spearfish-sample dataset.
 The nightly build is back. Using today's
 http://josef.fsv.cvut.cz/wingrass/grass64/WinGRASS-6.4.SVN-r43715-1-Setup.exe,
 the following command in spearfish60:
 g.region rast=elevation.dem res=30 -ag
 r.in.wms output=elevation_meters mapserver=http://wms.jpl.nasa.gov/wms.cgi
 layers=us_ned styles=real -0
 fails, with a following output in the beginning (full log attached):
 <cs2cs.exe>: while processing file: <stdin>, line 1^M
 pj_transform(): Unknown error^M
 (standard_in) 1: parse error^M
Ticket URL: <http://trac.osgeo.org/grass/ticket/820#comment:42>
