[GRASS-dev] Re: [GRASS GIS] #1180: g.extension fails on install step when GRASS is launched from source directory
GRASS GIS trac at osgeo.org
Wed Sep 29 06:14:46 EDT 2010
directory
 Reporter:  marisn       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.1
Component:  Default      |     Version:  svn-releasebranch64
 Keywords:  g.extension  |    Platform:  Linux
      Cpu:  x86-64       |
Changes (by hamish):
 * cc: frankie (added)
  * keywords:  => g.extension
Comment:
 [see also #1178, #854, and less so #620]
 on the DebianGIS list frankie wrote:
 I guess you mean
 # GRASS dirs
 GRASS_HOME          = /build/buildd-
 grass_6.4.0~rc6+42329-1+b1-i386-7qc3Bn/grass-6.4.0~rc6+42329
 RUN_GISBASE         = /build/buildd-
 grass_6.4.0~rc6+42329-1+b1-i386-7qc3Bn/grass-6.4.0~rc6+42329/dist.i486-pc-
 linux-gnu
 RUN_GISRC           =
 ${ARCH_DISTDIR}/demolocation/.grassrc${GRASS_VERSION_MAJOR}${GRASS_VERSION_MINOR}
 which should be:
 GRASS_HOME = /usr/lib/grass64
 RUN_GISBASE = /usr/lib/grass64 ?
 but what about the other dir?
 Francesco P. Lovergine
 short answer is that I'm not sure what RUN_GISBASE should be for post-
 build includes. FWIW the demolocation is used for building the
 documentation which generally needs the command to be run from inside a
 valid GRASS environment (`g.command --html-description`).
 with respect to where to install new addons on an end user's system
 (considering that they may not have sudo rights to put them in to /usr/ or
 /usr/local/, or C:\Program Files\), perhaps we could go for
 ~/.grass6/addons/ or so and then add that to GRASS_ADDON_PATH
 automatically (+additionally)? We could recommend that users add
 GRASS_ADDON_PATH to their .bashrc or equiv. in a closing message from
 g.extension, but it wouldn't always happen.
 need to have another look at how the linux R-cran installed packages
 register themselves, and maybe press the GRASS_ADDON_ETC into action (a
 home for user-installed addon man pages?)
 Maybe add a new flag to g.extension that tries sudo for a system
 wide install to /usr/local/ or /c/.../msys/... on Windows? (but then
 it's really up to the admin to make sure GRASS_ADDON_PATH is set)
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1180#comment:2>
