[GRASS-dev] Re: [GRASS GIS] #1180: g.extension fails on install
step when GRASS is launched from source directory
trac at osgeo.org
Tue Sep 28 05:56:30 EDT 2010
#1180: g.extension fails on install step when GRASS is launched from source
directory
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Default | Version: svn-releasebranch64
Keywords: | Platform: Linux
Cpu: x86-64 |
Comment(by neteler):
This is a know problem (same here). The problem that in this case the
source and target
install dir are the same. So a test would be needed to simply skip the
installation
then as not needed (note that g.extension was written for a properly
installed GRASS).
I tried to fix it but cannot obtain the related variables from the
Makefile job to
obtain the path names (essentially from Platform.make).
Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/1180#comment:1>
