[GRASS-dev] [GRASS GIS] #1180: g.extension fails on install step
when GRASS is launched from source directory
trac at osgeo.org
Tue Sep 28 05:38:58 EDT 2010
#1180: g.extension fails on install step when GRASS is launched from source
directory
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Default | Version: svn-releasebranch64
Keywords: | Platform: Linux
Cpu: x86-64 |
Tested g.extension with current 6.4 branch. Compilation goes fine, still
installation fails. It is possible to write into destination directory. I
run GRASS directly from source dir (no make install).
Installing v.profile...
+ grep 'default: script'
/home/maris/grass_data/personal_spearfish_60/user1/.tmp/glacier/5410.0/v.profile/Makefile
+ '[' 1 -eq 0 ']'
+ PROGTYPE=bin
+ test '!' -d /home/maris/soft/grass_64/dist.x86_64-unknown-linux-gnu
+ test '!' -d /home/maris/soft/grass_64/dist.x86_64-unknown-linux-gnu/bin
gnu/docs/html
gnu/man/man1
++ basename /home/maris/soft/grass_64/dist.x86_64-unknown-linux-
gnu/scripts/g.extension
+ touch /home/maris/soft/grass_64/dist.x86_64-unknown-linux-
gnu/g.extension.5410
+ '[' 0 -ne 0 ']'
+ rm -f /home/maris/soft/grass_64/dist.x86_64-unknown-linux-
+ test -f /home/maris/soft/grass_64/dist.x86_64-unknown-linux-
gnu/bin/v.profile
gnu/bin/v.profile
+ make MODULE_TOPDIR=/home/maris/soft/grass_64/dist.x86_64-unknown-linux-
gnu INST_DIR=/home/maris/soft/grass_64/dist.x86_64-unknown-linux-gnu
install
/usr/bin/install -c /home/maris/soft/grass_64/dist.x86_64-unknown-linux-
gnu/bin/v.profile /home/maris/soft/grass_64/dist.x86_64-unknown-linux-
gnu/bin/
/usr/bin/install: cannot stat `/home/maris/soft/grass_64/dist.x86_64
-unknown-linux-gnu/bin/v.profile': No such file or directory
make: *** [install] Error 1
GISBASE=/home/maris/soft/grass_64/dist.x86_64-unknown-linux-gnu
Ticket URL: <http://trac.osgeo.org/grass/ticket/1180>
